Multisim and Ultiboard
Renumbering Components in Multisim
I've been trying to rerumber the pins on a part to look like the "new" component below.
The previous way I've tried was relabelling them in the symbol editor which obiously didn't work. Is there an easy way to renumber the pins in left-to-right order?
Thanks!
(3,445 Views)
The symbol editor is the utility you can use to change the symbol. Unfortuantely, there is no quick way to do it. You will have to re-size the symbol and then start moving the pins around.
Hope this helps.
Tayyab R,
National Instruments.
(3,071 Views)
