Multisim and Ultiboard
Resistor 'Description' where to edit?
I'm not sure how this field was set but I cannot find where it is, can someone help point me to where you can edit the 'Description' field on a  component?
(2,972 Views)
Hi
Have you tried to modify the component? Look at this KB:
Component Editing
http://zone.ni.com/reference/en-XX/help/372062L-01/multisim/componentediting/
(2,934 Views)
It's a component in the master database, you cannot modify it. You can only change things like the value and footprint.
(2,932 Views)
Hi
The master database cannot be modified because it is the principal backup of the software components. What you can do is to move the part to the user database and then modify it there.
Moving Components Between Databases
http://zone.ni.com/reference/en-XX/help/375482B-01/multisim/movingcomponentsbetweendbs/
(2,921 Views)
I know that!!!
i didn’t modify this part at all, so where did this parameter get set?
Do you understand what I am asking??
(2,918 Views)
You didn’t understand my question.
(2,910 Views)
Senorship on this forum is pretty severe!
(2,909 Views)
