Multisim and Ultiboard
SMD part below THT part ???
How I can set SMD part (from BOTTOM pcb layer), under the integrated circuit U3 (from the TOP layer) - see the image below?
If I try to move SMD part,  but "THT part  run on pcb surface".
Is there a setting or method by which I could put on the bottom SMD part below U3, I would like to know, please!
Best regads,
pub2050
(4,675 Views)
I'm not sure what the reason could be.
it should work normally...
-have got the 'part shoving' switched off? You can find this under the 'design' tab.
-have you set your net clearances small enaough (try 0.25 mm or 10 miils) so the copper pads are not too close.
Another tip:
From a production view, it is better to have all your parts on one side, SMT as well as  THT.
It just saves you a lot of money in series production...
succes!
Stressed user
(4,637 Views)
I switched ON  "part shoving" and now it works. Thanks.
(4,603 Views)
