Multisim and Ultiboard
SPICE model for TI TLV61220 not working
Hey!
I've downloaded the official SPICE simulation files from TI here.
In Multisim i use the component wizard to import the SPICE model. I get exactly the error, described in this post, but the solution there isn't helping. There's a sentence: "Select just the ones  that you need" but that isn't helping me eighter, because i don't know which ones i really need. I also read that question, but for me, he just randomly moves a `.ends` to a different position.
thy for helping already
~Newton
(.zip file from TI attached, simulation files are names TPS61220 but they're from the site of TLV61220)
(2,173 Views)
Accepted by topic author Newton_
fixed my first problem: there was a missing clip at a power source table (i found it using VSC with a SPICE-Extension).
now, i get the following error, when i try to start a simulation:
(2,099 Views)
fixed that too, i've missed some .subckt that were required too
(2,091 Views)
Тогда рабочую модель в студию! И файл с расширением "ms", как живой пример достижения успеха, для нашего обучения...
(2,072 Views)
Hey again!
Now i've got the next problem with this simulation:
As i try to start a simple build with the TLV61220 model, i get a simulation-error. First time I tried to autofix it, it said the autofix worked, but the result was smth wrong. Now I tried autofix again, this time it cancelled the autofix. My current SPICE Model and the NI-Multisim-Simulation are attached.
thx for your help
Newton
Screenshot from TLV61220 datasheet
(1,923 Views)
fixed that myself too: i've missed a ground
(1,911 Views)
