Multisim and Ultiboard
Schematic entry issue
I have some legacy schematics originally captured with Multisim 8.  I'm trying to rearrange parts and wires to make the schematic more readable.  I've tried this in Multisim 8 and an evaluation copy of Multisim 10.1.
One problem I've had is moving a 'T' shaped junction.  If I move the left top of the 'T' down and then the right top, I tend to get a '+' rather than a shorter 'T'.  I have to explicitly put a join on the center of the '+' then select the top part of the upright and delete it.  Is there a simpler way?
I have a somewhat more serious problem:  I moved a set of junctions connecting a ground to a set of parts (microphones).  When I dumped a netlist, the wire  connecting the uppermost mic to the rest of the grounds (at least visually) was not in net 0.  I'm sure I can fix it, but my point is that there's no clear visual indication that the connection is not correct.  I had to dump a netlist and compare it with the original netlist to find the problem.
Message 1 of 1
(3,753 Views)
