Multisim and Ultiboard
Scheme doesn't work [pics, original sheme]
http://tangentsoft.net/audio/cmoy-tutorial/misc/cmoy-tangent-sch.pdf
Original schem
http://img265.imageshack.us/my.php?image=cmoyds5.png
My sheme
Please help me figure out, how to run scheme
By the way tous "Vcc t's" are unknown elements to me.
(without power sheme runs without errors)
And if some1 konws where to find sixpin potensiometer then please make me smarter ^^
Thaanks,
jaan
[URL=http://img127.imageshack.us/my.php?image=1205925297488sjt5.jpg][IMG]http://img127.imageshack.us/img127/4089/1205925297488sjt5.th.jpg[/IMG][/URL]
(3,906 Views)
Alrighty, I have managed to get it working. I will post the file with my adjustments outlined with in it for you to examine. There was a weird situation that I encountered with this circuit when trying to get it working that should be looked at by NI as it may be a software problem or model problem.
This is for NI: If you look at the original circuit you will notice that both halves of the circuit are wired identical with a 2 section op amp. If you run a simulation one amp gives good results while the other amp doesn't. Both amps are from one multi-section component. They should give identical results but don't. The only way I could get the proper results was to remove section B of U1 and replace it with the same type op amp but labeled as U2A. in essence having 2 separe IC's on the print instead of one multi-section amp. This has to be an error in the way Multisim is handling multi-section components that needs to be examined and corrected.
Here is the file
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(3,890 Views)
Iacy shud be moterator on this forum, thanks you.
Your explanations helped me much
(3,884 Views)
