Multisim and Ultiboard
Sending data to Multisim
Hi, evry!
For my current task I need to feed a circuit in Multisim not with standard Multisim-generated signal, but with the special video signal received from IO-board as an X-Y array of points.
How can this be done?
Thanks in adv.
(3,463 Views)
Can you tell me are you expecting an array of points at every time point, or is X time and Y voltage/current? If it is the latter, then you have a number of options, but if it is the former, you're going to have a very different problem, and the only possible solution I see would be through a custom LabVIEW instrument, and the details of that will depend on exactly what you are trying to achieve.
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(3,429 Views)
Thanks, Garret!
And, ah, everything I need is seems to be described here :smileyvery-happy::
http://zone.ni.com/devzone/cda/tut/p/id/4330
If any questions arise, I'll certainly let you know.
Thanks again.
(3,412 Views)
