Multisim and Ultiboard
Signal to Noise Ratio
Is there anyway to measure the signal to noise ratio in Multisim circuit.
Thank you
(4,407 Views)
okogidi,
yes, Multisim can perform Noise analysis on a circuit (simulate->analysis->noise analysis). Resistor thermal noise and Semiconductor shot noise are modeled when performing this analysis.
Your SNR is simply the signal power at some node divided by the total noise power that noise analysis calculated.
There's an excellent tutorial on how to perform noise analysis in SPICE at http://ecircuitcenter.com/Circuits/Noise/Noise_Analysis/res_noise.htm
Max
Max
(4,399 Views)
