Multisim and Ultiboard
Simulate Menu not appearing
Hi
I installed the MultiSIM and UltiSIM. Since the network connection is slow the application is not able to connect to the server. But other pages are opening. And it says the software will function with limited facilities. And the Simulate Menu is not visible when the MultiSIM opens. Please tell me some corrective measures that I should take.
Thanks in advance.
Gokul.
(5,053 Views)
There are two things that may prevent you from connecting to the server:
1.  Your firewall is blocking www.electronicsworkbench.com port 80
2.  You are behind a proxy server, the link below will provide more info.
http://zone.ni.com/devzone/conceptd.nsf/webmain/DAD2C61E475709E5862571790029B525
(5,012 Views)
