Multisim and Ultiboard
Simulating with a PWM source?
Is there a way to simulate with a PWM source?
It could be a voltage controled duty cycle at a preset frequency.
Thanks.
(7,959 Views)
Accepted by topic author dbur
You can read this from our KB (knowledge database), it even has a sample to see how it works.
Link
http://digital.ni.com/public.nsf/allkb/EF391C48CF71AE4F862571B900644F84
EDIT: I forgot to add that depending on the version and type of multisim, there is an entire section for PWMs and other uses under the POWER family.
Cheers,
Miguel V
(7,953 Views)
There are a number of ways to do this, all of which revolve around comparing a control signal to a triangular swithcing waveform. This is the basis for PWM generation.
In Multisim V12, to simply this popular task we added parameterizable components that do exactly this. Look under the Power/POWER_CONTROLLERS family.
Max
(7,944 Views)
The PWM block worked much better than using two sources and an ideal comparator, though they should have produced the same result.
Thanks.
(7,918 Views)
dbur,
This might have something to do with the time step settings.  If you let Multisim set TMAX automatically (default) and you are using a built in source, Multisim will take that into consideration and overestimate TMAX (such as with the case with a rapidly changing PWM signal, it will take into account the rise/fall time of the edges).
However with another source like a triangle or sinusoid and a comparator, Multisim will likely not overestimate on the TMAX to accurate represent the rise/fall time at the output of the comparator (the tool is not aware of the "comparator" from a SPICE model standpoint).
So for you to get equivalent results, you may have to set the TMAX manually (it defaults to 1E-5 when set to manually mode, but for accurately representing the falling/rising edge of a PWM signal you may want to go to 1E-8/1E-9 or smaller as the maximum time step (TMAX).  There will be a direct correlation between simulation time, accuracy and TMAX (which for manually setting of TMAX, you will need to balance to get a sufficient simulation, yet in a timely fashion).
To configure from the menu in an interactive mode simulation, go to:
Simulate -> Set maximum timestep (TMAX) and then select (*) Maximum time step (TMAX):
;and set to a small enough value to capture the rising/falling edges of the PWM signal.
- Pat N
(7,876 Views)
Yes, this is what I have learned as well.  I did receive some result imporvements by tightening many of the simulator tolerances as well.  I am assumming that causes the simulator to shorten the time steps further (and maybe other things) when signals are active in order to solve to smaller errors.
(7,866 Views)
