Multisim and Ultiboard
Simulation results as an audiable output
I am building AF devices and was wondering if there is a way to hear an audiable result, of a simulation, as opposed to only visual waveform analysis? Thoughts are appreciated. Thanks in advance.
Chris
(4,948 Views)
Hello Chris,
I would like to show you an article that might help you.
  • Simulating a LabVIEW Speaker and Microphone in NI Multisim
http://digital.ni.com/public.nsf/allkb/42A992A951D71B3E86257B500053B90D
Please let me know if this information was helpful.
Luis
(4,929 Views)
Hi Luis,
Thank you for your quick response. I am going to put this to the test, shortly. I will keep you posted on the results.
Best,
Chris
(4,857 Views)
Hi Luis,
I finally tried to use the speaker instrument based on your link. This would be excellent, if it was not for the fact that, for some unknow reason, when I playback, after simulation, the speaker only plays a short blip of my simuilation output. The speaker tool does give me the option to modify the default recording time, 1 second, to other values. However, when I modify the record time, I still have the same results with play back time being a small blip. Any thoughts?
Best,
Chris
(4,099 Views)
