Multisim and Ultiboard
Simulation slow
Hi Guys,
i have a friend who has been using Multisim for a couple of years, but he has always said it would be nice if was it bit faster. He has upgraded the PC with a beast of a video card (nvidia rtx4090), I helped him migrate the application to the new PC but it is still slow.
Basically when he plays the simulator for the schematics he has created and looks at the oscilloscope the wave is very slow but when he zooms in on the schematics the wave on the oscilloscope speeds up.
Is there a way to fix this or has anyone experienced this.
Thanx in advance.
(1,588 Views)
If your "friend" has a problem, maybe he should post here and provide significantly mode detail.
  • What does the simulation do?
  • What is the CPU and memory used during simulation? For example is one CPU core saturated?
  • The term "slow" can have many different meanings to different people, so please define it?
  • Throwing a high powered video card at a problem seems completely misguided, especially since the GPU is probably not used for any of the calculations.
(1,586 Views)
Changing analysis parameters changes the speed of simulation
(1,550 Views)
Ill advise my friend to adjust the parameters as provided and see if that helps, if not I will see if a can get a screen recording of the issue he is encountering.
Note: The circuit is very complex. Is multi sim limited with the size of the circuit?
(1,455 Views)
We have adjusted the parameters and still slow, any other suggestions.
(934 Views)
