Multisim and Ultiboard
Software Update 11.0.0.1 for NI Circuit Design Suite
The latest software update for NI Circuit Design Suite 11 is now available via NI Update Service. This update (11.0.0.1) is available to all 11.0 users, and contains 17 user-reported defect-fixes for Multisim and Ultiboard. The update is applicable to all editions including Power Pro, Full, Base, Education and Student, and installs on top of a pre-existing 11.0 installation.
The preferred method of installation is via NI Update Service:
1. Close any open sessions of Multisim/Ultiboard
2. Go to Start > All Programs > National Instruments > NI Update Service
3. Select Check for Updates
4. Select the checkbox for NI Circuit Design Suite 11.0.0.1 and click Install
Update service will download the update, and proceed to launch the 11.0.0.1 installer.
Alternatively, if NI Update Service is unavailable, the 11.0.0.1 Update can be manually downloaded from the Drivers and Updates website.
After completing the installation, the Help > About Multisim dialog will display version 11.0.0.1 (11.0.405).
Message Edited by NatashaB on 04-12-2010 11:16 AM
Message Edited by Support on 04-12-2010 11:50 AM
Natasha Baker
R&D Engineer
Join the NI Circuit Design Community
Follow Multisim on Twitter!
Message 1 of 30
(7,216 Views)
This update fails to install on my computer either thru the updater or manually. The updater downloads the file, it executes briefly, and then says that no changes were made. The Multisim version remains the same.
Message 2 of 30
(7,133 Views)
I suggest you send a support request to ni.com/support. They should be able to help troubleshoot your issue.
Natasha Baker
R&D Engineer
Message 3 of 30
(7,103 Views)
Installed fine on Win7 x64.
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
Message 4 of 30
(7,050 Views)
It installed OK on a Win XP Pro SP3 (32bit version).
lepton
Message 5 of 30
(6,984 Views)
win7 x64  won't install
Message 6 of 30
(6,929 Views)
Sure it does, something wrong on your end, are you installing as an administrator?  I have it on two win7 x64 never an issue.
Message 7 of 30
(6,912 Views)
run as admin, security software disabled, fresh reboot, ni-updater, manual install. I've tired everything I can think of. It will not install. It does not give any indication of why. Just flashes a dialog box stating that nothing is changed.
Message 8 of 30
(6,892 Views)
are there any command line switches for the installer that will make it a bit more verbose?
Message 9 of 30
(6,890 Views)
Same problem for me.  Seems to install but says nothing has changed. Version is not updated.  Finds update again when I check for updates again.
I am installing as administrator.  Windows XP SP3.
David B
Message 10 of 30
(6,823 Views)
