Multisim and Ultiboard
Spektrum­analysa­tor
What I have to change to keep the range up to 20 kHz on the display ?
(2,218 Views)
Hello, you can stop your spectrum analyzer from the Stop button, then set your frequency range. You can either set interval limits or center frequency and span. Press Enter/Eingeben on top of the frequency settings section and start your instrument from the Start button. There you go, you should now have your frequency range set.
(2,124 Views)
Thanks ,
(2,112 Views)
