Multisim and Ultiboard
Suggestion for Multisim parts placement upon transfer to Ultiboard
Next update for Multisim, please make the default non-polar capacitor option (film, ceramic, mica) one which matches the outlines in Ultiboard.  The default option seems to be a radial electrolytic -- not helpful if you are writing in a a bypass or timing cap.  Last time I used a radial electrolytic was in the 1990's.
Here's why you have to fix this -- when you transfer to UB you've got a bunch of devices where the pads/holes are named with a "+" and "-" rather than "1" or "2".  You can't automatically "Replace Part" with a non-electrolytic as you immediately have a DRC error!  AND you get a design error with the "+" sign repeated on the device.  This makes for a time consuming mess with the netlist editor.
By the way,how are you doing replacing the greek letter "mu" upon transfer to UB?
(3,569 Views)
Jackinnj,
I've replicated the swap behavior and I'll advise R&D of the potential issues and the feature suggestion to allow a SMT default (actually the default in v12 is no shape in the first use).
Also if you select a certain SMT shape from the Master parts list for RLCs, any subsequent use of that RLC part type should default to the same SMT footprint shape.
Pat Noonan
(3,559 Views)
