Multisim and Ultiboard
Summing Amplifier
Design and simulate a summing amplifier with the ability to sum different number of small-sized coin (S), middle-sized coin (M) and large-sized coins (L) and produce the result in total points available. S has 1 point, M has 2 points and L has 3 points. The values 7, 5 and 9 are used as input. All calculations must be shown and Multisim circuit output is required.
May I know where do I start? Here is my attempt. (Forum.ms14)
(2,598 Views)
Hi!
It would be good to check the following documentation:
https://www.electronics-tutorials.ws/opamp/opamp_4.html
https://www.elprocus.com/summing-amplifier-circuit-with-applications/
If you follow this and design it on paper, then you can transfer it to Multisim.
Have a great day.
(2,519 Views)
