Multisim and Ultiboard
TC4420 and LEM HXS50NP
Hello.
I need to develop one small project where i have to use TC4420 and HXS50NP.
Those symbols are not in the multisim database. Does someone knows where i can find it or download it ?
If i have to create new symbols please tell me how to do this.
I need just for those two.
Hubert
Message 1 of 10
(5,925 Views)
i forget to write that any alternative could also be ok.
Message 2 of 10
(5,922 Views)
unfortunately, NI has no templates for TC4420 and HXS50NP. Maybe you find something on Google.
Best regards
Marko
Message 3 of 10
(5,900 Views)
Huby,
1. There is a manufacturer supplied model for the TC4420 on the Microchip site.
http://ww1.microchip.com/downloads/en/DeviceDoc/SPICE%20Models%20for%20TC4420-29%20MOSFET%20Driver%2...
Please attempt to create this part using this model and the tutorial - come back and reply if it doesn't appear to work (post a test circuit for others to benefit from if you get close).
Tutorial: http://www.ni.com/white-paper/3173/en
2. Also there does not appear to be a model for the LEM current transducer, however it may be relatively easy to mock up a simplified model using  a Current Controlled Voltage Source (or "H" source if familiar with SPICE syntax).  You can find that component here:
Master DB -> Sources -> CONTROLLED_VOLTAGE_SOURCES -> CURRENT_CONTROLLED_VOLTAGE_SOURCE
You could also look at the datasheet and enhance its functionality according to any functional block diagrams that may be included.
Pat
Message 4 of 10
(5,888 Views)
Thank you for this model !
I implement this into symbol specifications and on first test i get this error messages:
SPICE Netlist Error in schematic RefDes 'u1', element 'g62': Unexpected ')' found in function ''
SPICE Netlist Error in schematic RefDes 'u1', element 'tc4420__tc4420__1': Due to errors, the component 'g62' has been omitted from the simulation
SPICE Netlist Error in schematic RefDes 'u1', element 'r53': Unable to interpret 'tc'
SPICE Netlist Error in schematic RefDes 'u1', element 'xu1': Unable to interpret 'du1.5'
SPICE Netlist Error in schematic RefDes '', element 'aadcin1': Digital and analog pins are connected on node '$du1.1'.
SPICE Netlist Error in schematic RefDes '', element 'aadcin1': Due to errors, the component 'aadcin1:xu1.1' has been omitted from the simulation
SPICE Netlist Error in schematic RefDes '', element 'aadcin1': Digital and analog pins are connected on node '$du1.4'.
SPICE Netlist Error in schematic RefDes '', element 'aadcin1': Due to errors, the component 'aadcin1:xu1.4' has been omitted from the simulation
======= SPICE Netlist check completed, 8 error(s), 0 warning(s) =======
The pins are defined as folows:
1 - vdd
2 - input
3 - NC
4 - gnd
5 - gnd
6 - out
7 - out
8 - vdd
Any idea what this could be ?
Message 5 of 10
(5,878 Views)
Please include the circuit.
Message 6 of 10
(5,875 Views)
I think i found the error.
http://oi48.tinypic.com/bhepmb.jpg
How to define "duplicated" pin names ?
I can not choose pin numbers ( as described in tutorial ).
All i can choose are the definitions that i create before.
There must be some step that i missed but i have no clue which one.
I created the same object 3 times and each time the same problem.
Message 7 of 10
(5,872 Views)
If you don't need a footprint you can go back to step 1 and create a simulation only (model only) part...
If you do need a footprint, in the symbol you can do 1 of 2 things.
1. Create more than one symbol pin name with an underscore "_x" and map them to a unique footprint name.
2. Create a single symbol pin (ie 'gnd') and map this to multiple pins.
- Pat N
Message 8 of 10
(5,869 Views)
I took screen shoots of each step. This way it should be easy to follow.
Anyway... before i test it with circuit i try to run without and parts.
No luck, almost the same error.
If i make test with some other cmos component that is already in database, everything works OK
http://oi46.tinypic.com/1zx8mte.jpg
Huby
Message 9 of 10
(5,857 Views)
Any idea how to solve this ?
Is this some bug or something else ?
Message 10 of 10
(5,846 Views)
