Multisim and Ultiboard
THD Compensation
I have made an inverter circuit and my output waveform appears to be perfectly sinusiodal. However my THD is 72% which doesnt seem to represent my waveform. I need help either filtering the harmonics within my circuit to bring my THD below 10%.
(4,061 Views)
HI,
I've ran the circuit and I'm not seeing a perfect sine signal, and I'm pretty sure that's where the issue relies. My recommendation on this is to re-built your circuit in order to get a better sine signal.
Luis G.
(4,016 Views)
Can you send me a photo of the sine wave you see. The wave I see doesn't seem to have a 72% THD
(4,010 Views)
Take a look at the picture.
(3,999 Views)
Ok. I get the same. Does that seem to warrant a THD of 72%? If so, how can I filter it to make it better?
(3,996 Views)
