Multisim and Ultiboard
TL084 component creation multisim
I created an IC of 14 pins but it does not work. It is an op-amp. please help
(6,589 Views)
The model you used is only for one opamp section, if you want to use the Opamp as a complete IC, you have to modify the model.
Try the attached model, I made the require changes to the model.
Tien P.
(6,574 Views)
Hi thanks, am still getting errors from it. it still gives errors here
------ Checking SPICE netlist for Design1 - 10 November 2013, 14:05:30 ------
SPICE Netlist Error in schematic RefDes 'u1', element 'x1': Invalid subckt definition name '1'
SPICE Netlist Error in schematic RefDes 'u1', element 'tl084__opamp__6': Due to errors, the subckt instance 'x1' has been omitted from the simulation
SPICE Netlist Error in schematic RefDes 'u1', element 'x2': Invalid subckt definition name '7'
SPICE Netlist Error in schematic RefDes 'u1', element 'tl084__opamp__6': Due to errors, the subckt instance 'x2' has been omitted from the simulation
SPICE Netlist Error in schematic RefDes 'u1', element 'x3': Invalid subckt definition name '8'
SPICE Netlist Error in schematic RefDes 'u1', element 'tl084__opamp__6': Due to errors, the subckt instance 'x3' has been omitted from the simulation
SPICE Netlist Error in schematic RefDes 'u1', element 'x4': Invalid subckt definition name '14'
SPICE Netlist Error in schematic RefDes 'u1', element 'tl084__opamp__6': Due to errors, the subckt instance 'x4' has been omitted from the simulation
======= SPICE Netlist check completed, 8 error(s), 0 warning(s) =======
(6,542 Views)
I made a couple of mistakes with the node.  Try this circuit.
Tien P.
(6,519 Views)
