Multisim and Ultiboard
TRIAC Light Dimmer commanded by DIAC
Good morning everyone !
I hope that you are not annoyed with the COVID-19.
I am trying to simulate a simple circuit with one TRIAC commanded by a DIAC, but it seems that the components doesn't work properly... Maybe I made a mistake...
Here is my simulation:
Whenever I change R2's value which is supposed to modify the command angle of the TRIAC, nothings change... Have you got an idea ?
Thank you, and have a great day !
Nathan
(3,681 Views)
I've found the solution. The green component indicates that no simulation model is associated with it. Had to take another triac.
(3,626 Views)
