Multisim and Ultiboard
TSV to XMLNI
NI's VLM software allows me to export data in TSV and XML format, but it can only import data that is in XML format. I need to create the VLM accounts for a few hundred users. I have the data in an Excel spreadsheet, which I can export to CSV.
Is there an easy way (program/plugin) which will allow me to either
i)  convert data from CSV to XML format so that it can be imported into VLM, or
ii) allow VLM to read CSV/TSV files directly
I know that I can edit the XML file directly and cut & paste the new account information into the file. It becomes very tedious when you have a few hundred users and doesn't make sense when I already have the data in Excel csv format.
Any suggestions welcome. Thanks.
(3,780 Views)
Problem resolved; I wrote a small program which converted the data from csv to VLM's xml format.
(3,758 Views)
