Multisim and Ultiboard
Temeprature Sweep Analysis in Multisim
In Multisim, in Temperature Sweep Analysis; in room temp as well in –ve temperature it gives the 5% variable wrt practical results.
But in +ve temperature sweep analysis, the results are as same as room temperature and variation is very small wrt to room temp analysis.
Is it because of model selected (i.e. Transistor or FET) or because some limitation of simulation?
 Do we need to download spice netlist for these model or model available is having accurate parameter?
(3,528 Views)
 Please specify what kind of simulation you are doing? and what circuit are you using for sweep analysis?
(3,497 Views)
