Multisim and Ultiboard
Temperature Coefficient Zener Diode
Hi All.
The attached circuit has two zener diodes, one 3V3 and the other 6V2.
Both diodes (BZX384) show a linear negative temperature coefficient
between 20 and 180 degrees Centigrade, whereas the 3V3 should be
-2.4mV/degree C and the 6V2 diode +2.3mV/degree C.
I have not changed the models. I hope someone can tell me I am an
idiot or I will have lost faith in the temperature modelling.
Keith
(3,534 Views)
Hi Keith,
Thank you for your post.
Please may I ask what you are trying to do? Also, please may I ask for more details on your setup.
Kind regards,
YD
(3,511 Views)
Hi Yusuf.
I wanted to create a constant voltage, similar in action to a zener diode,
with near to zero temperature drift. To create this I was going to use the
combination of a zener diode and bipolar transistor. I have looked at using
shunt voltage references, but they all rely on a low impedance ground
because of the circuitry contained within. They are not suited to being
operated in series with a resistor in the anode and cathode.
Whilst pursing this task, the circuit I designed did not have the thermal
characteristics I was expected. Following on from this, I swept the
temperature of a BZX384 6V2 to find it's temperature coefficient
was negative rather than positive. The same negative coefficient
applied to the 3V3 diode. The circuit I presented was my test
circuit which need not be any more complicated for this purpose.
However, I should have only placed one probe on circuit so the resulting
graph had a much limited range of about 100mV.
Basically, I should have just asked the community where the
temperature coefficient  was stored the the BZX384 model, and, if not
included, what should it be.
Thank you,
Keith
(3,503 Views)
Hi Yusuf.
Thank you,
Keith
(3,501 Views)
