Multisim and Ultiboard
Temperature sweep analysis problem
Hi folks, i'm having problems to plot a simple temperature sweep analysis.
I've created the NTC sensor with the follwing spice program:
.SUBCKT ultimo 1 2 PARAMS: T0=25 R0=10k T1=120 R1=300
R1 1 2 (R0*((R1/R0)^((T0*T1-TEMP*T1)/(TEMP*T0-TEMP*T1))))
.ENDS
The graph should do a Temp vs Tension in a determined point of circuit. Does someone knows how can i correct this?
(2,860 Views)
Hello, jucimar.carpe
I've tried to perform a Parameter Sweep using temperature as the sweep parameter and the problem I've faced here was not to find your NTC temp param. Is that the issue you are having there?
Plínio Costa
Senior Techinical Support Engineer
National Instruments Brazil
(2,698 Views)
