Multisim and Ultiboard
This circuit has no power sources: unable to determine the simulation timestep automatically. Please add a power source or set the simulation timestep under "Interactive Simulation Settings" to proceed.
Hi again.
I built this circuit but I keep getting the error message in the title.  I have gone through the older threads on it but can find nothing to help.  If I run the digital smaples they work fine.  If I run other digital circuits I made they work fine.  I have tried this circuit on another PC and get the same error.
Any help would be greatly appreciated.
Ray
Message 1 of 9
(5,552 Views)
Problem is a phantom net that doesn't exist.  Go to tools, update circuit components and click update.  That should fix it.
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
Message 2 of 9
(5,547 Views)
Followed the procedure I just told you, and it works fine.........again.  I've attached the fixed version, see if it works there now.
Message 4 of 9
(5,515 Views)
Thanks, it works fine on my MS.  I was planning on rebuilding the circuit to see if there was something I was doing wrong.
I may open the code and see what's different.
This is very strange.  I even did a "repair" on Multisim.
Thanks again.
Message 5 of 9
(5,505 Views)
Okay, I built the same circuit and got the same error.
One thing I noticed is that on your fixed circuit the 7408 gates are all on different chips.  I created the circuit using all the gates on one chip.
I am really confused.
Could it have anything to do with the fact that I am running this on W7 64bit?
Message 6 of 9
(5,501 Views)
I built the circuit again using different chips for each AND gate and it worked the first time.  I did use the same chip for the Inverter gates.
I don't get it.
Message 7 of 9
(5,492 Views)
same deal, error with the first shot, updated components as above, rerun, no issue.
Message 8 of 9
(5,490 Views)
One thing.  When  I go to tools - update....  The "update" button is not active.  I have to select one of the boxes above to get the "update" button to go active.  Any thoughts on that?
Message 9 of 9
(5,488 Views)
