Multisim and Ultiboard
Trace width combo box not taken into account
New in Ultiboard 10.1:
I noticed that you cannot select a width value in the Trace properties dialog using only the combo box. Per example, I have a net that was manually set to 1 mm. If I want to select "Use Net Settings" instead, the action is not executed. It works only if I type something into the box.
I verified and that bug was not there in version 10.0.
Alex
(3,446 Views)
Accepted by topic author alexbilo
Hi Alex,
The problem is the Apply button doesn't become active and if you click the O.K bottom the dialog box closes and the setting doesn't change, my work around is to click on the  Trace Fixed radio button and then Trace Can be Move bottom again, this should activate the Apply.  This is a known bug and it's in our system.
Tien P.
(3,433 Views)
