Multisim and Ultiboard
Transferring Multisim 11 to a laptop with no internet access
I thought I found the answer to this the other day, but I can not seem to locate it again.  I am trying to transfer my Multisim 11 from a computer with an internet connection to a laptop without internet connectivity.
(5,048 Views)
You can download the Circuit Design Suite installer the links below:
Education or Student Edition:
ftp://ftp.ni.com/evaluation/Circuit_Design_Suite/11.0/NI_Circuit_Design_Suite_11_0_Edu.exe
Professional version:
ftp://ftp.ni.com/evaluation/Circuit_Design_Suite/11.0/NI_Circuit_Design_Suite_11_0_Pro.exe
Once you've installed the Multisim, you should be able to activate it without internet connection. Obtain the computer ID from the computer without internet connection; refer to this knowledge base if you don't know how:
http://www.ni.com/license/activation_faq . You can generate the activation code from the computer with internet connect here: http://delta.ni.com/nilg/jsp/customer_activate_initial.jsp
You can also select the Phone option from the Activate Wizard screen and follow the on screen instructions to obtain the code.
Tien P.
(5,029 Views)
