Multisim and Ultiboard
Transient Time Point Calculation error
Hi guys,
I'm new to Mutlisim and can't figure out why the simulation won't run for this oscillator schematic.
I'm getting an error that says "Transient time point calculation did not converge". The convergence assistant wasn't any help.
What am I doing wrong?
Thanks in advance
(5,086 Views)
Hi  oldenjon!
Convergence issues are usual in any simulation environment, in order to get the cicruit to converge, I would recommend you to follow this document as a first step. Since every circuit ends up being a different whole model, simulations settings need to be adjusted in order to get the software to converge. If the specific vlues suggested in the document do not work, I recommend you to play around with the values a bit. I hope this helps!
WenR
(5,055 Views)
