Multisim and Ultiboard
Trying to incorporate a user defined expression/function for a Resistor
Гуд дэй, коллега!
There is a wonderful component in the program that changes its resistance according to the most incredible laws that our imagination can come up with!
Message 11 of 14
(552 Views)
That component seems very interesting, I'll take a look at it tomorrow! It's 12:30am for me right now 😞
Message 12 of 14
(547 Views)
hey fofango, is there anyway I can contact the Multisim staff to submit a potential request to look into variable circuit parameters? Because I found that you can do mathematical expressions like what we discussed earlier in the forums for a resistor labeled 'r'. However I noticed a couple of things. I noticed that when trying to add circuit components instead of a constant value such as V(1) and I(R1) the circuit parameters don't read it and it gives a inital  (preview) constant value of 0 which doesn't change at all during the transient simulation. Also when applying a resistance of any mathematical function 'r' as a function of time for example, the current is a constant value based on the inital (preview) value of r to match with the constant voltage in the system and it doesn't apply the changes to the current after the inital resistance thus making the current a constant which doesn't make sense.
Thanks for your time and help,
Elias
Message 13 of 14
(487 Views)
Hi!
Post specific examples of your simulations in 'ms' format. So I could understand more clearly
Message 14 of 14
(468 Views)
