Multisim and Ultiboard
UB mouse wheel zoom problem
I've recently started having a mouse wheel zoom problem in UB.  It used to zoom in and out on the cursor positon which would stay fixed relative to the place I have it on the layout.
Now the low out positon jumps all over the place sometimes putting my design way off in space to the side where I can't see it.
If I zoom real slow and reposition the cursor I can keep the design on the screen, but it's quite painful compared to how I'm used to having it work.
Any ideas?
I use an MS USB optical mouse with scroll wheel.  Win 7, 64bit, Phenom II 1100T processor. UB 11 (latest)
Message 1 of 16
(5,352 Views)
Check, in what condition at you a choice of the centre of zoom
Message 2 of 16
(5,347 Views)
I had it set correctly, and have never changed it.
I did try unchecking centering, click apply, then check it again and click apply and now it seems to work again.
Thanks.
Message 3 of 16
(5,338 Views)
Well, it's doing it again.  Toggled the centering selection does not fix it anymore.
Actually, unchecking centering now makes it behave as if centering was checked.     ??????
Message 4 of 16
(5,326 Views)
dbur,
Try this: Locate your user preferences / configuration file.
http://digital.ni.com/public.nsf/allkb/2719D00E36A4D53A8625721300685B3F
Copy it here or email it to me so that I can have R&D check it out (also keep a copy in the event this doesn't fix the problem).
Per the instructions delete the file from this location and restart Multisim/Ultiboard. Let me know if this fixes the problem.
Pat
Message 5 of 16
(5,320 Views)
Here is the config file.
When I started UB today it was working again.
I don't think the issue is teh centering option in the global settings.  When the problem is occurs it doesn't behave like either setting should.
Message 6 of 16
(5,314 Views)
Restoring a saved config from when it worked did not help.
Deleting the config and restarting also did not help.
Message 7 of 16
(5,306 Views)
Hi, would it be possible to confirm that you can see the same behaviour with another mouse? I had this behaviour once in the past (about a year ago) and it was caused by a faulty mouse I had. I replaced it and everything was OK after.
Nestor
Message 8 of 16
(5,284 Views)
The mouse has been working fine in all other apps.
I did try another mouse and it is working right now, though the old mouse is also working again as well (for now).
Win7 did install a mouse driver update when I plugged in the new mouse.
If the problem recurrs I will return and report.
Thanks.
Message 9 of 16
(5,281 Views)
Well, it worked for a few minutes and then is happening again, with both old and new mouse, and after unplugging and replugging the mouse and re-starting UB.
Message 10 of 16
(5,279 Views)
