Multisim and Ultiboard
Ultiboard 14.0 : Drill file is corrupted
Anton,
I'll ask a colleague at the university to help me with Ultiboard 13.
Lieven
Message 11 of 13
(2,428 Views)
Hi Lieven,
The behavior in Ultiboard 14 is intended. The format has been updated to to follow the Excellon standard fromat, where the decimal points are implicitly defined. So in a sense, it is actually the drill file in Ultiboard 13 that is corrupt. 🙂
/Anton
Message 12 of 13
(2,198 Views)
We are having the same problem with 14.0  if you change your output to mm then it will output the files correctly.  There seems to be a scaling issue with the inches output for NC drill
Message 13 of 13
(808 Views)
