Multisim and Ultiboard
Ultiboard 14 - Not possible to setup DRC
I'm trying Ultiboard version 14. I cannot setup correctly the DRC parameter as only clearances to trace is configurable. The checkbox to enable all other clearances is not present in the DRC tab. In the previous version this selection was possible. Could you help me ?
(3,119 Views)
Are you trying to configure the way described in this document?
http://digital.ni.com/public.nsf/allkb/E3E97A3A493309B786257AF6004FA55F
(3,023 Views)
I know this document. But i wonder that it is possible to set only the clearance to trace in the "Option-PCB Properties-Design Rules" menu ; in the previous versions there was a box to check in order to enable other clearances (i.e. pad-pad , pad-trace and so on) . This box disappear only in 14 version...... strange.... it seems a bug
(3,020 Views)
