Multisim and Ultiboard
Ultiboard - AP Circuits - Filename Conversion
I submitted a job to AP Circuits recently (www.apcircuits.com - very fast service) - I thought this may be helpful to some. Filename conversions from Ultiboard to AP Circuits requirements are as follows, and need to be added to AP Circuits order text file if you submit the job by email:
GERBER TOP LAYER FILE NAME: [Yourfilname] - Copper Top.gbr
GERBER BOTTOM LAYER FILE NAME: [Yourfilname] - Copper Bottom.gbr
GERBER TOP SOLDER MASK FILE NAME: [Yourfilname] - Solder Mask Top.gbr
GERBER BOTTOM SOLDER MASK FILE NAME: [Yourfilname] - Solder Mask Bottom.gbr
GERBER TOP COMPONENT MASK FILE NAME: [Yourfilname] - Silkscreen Top.gbr
GERBER BOTTOM COMP MASK FILE NAME: [Yourfilname] - Silkscreen Bottom.gbr
GERBER MECHANICAL FILE NAME: [Yourfilname] - Board Outline.gbr
GERBER APERTURE TABLE FILE NAME: Unidentified--
ASCII NC DRILL FILE NAME: [Yourfilname] - Copper Top-Copper Bottom.drl
NC DRILL TOOL SIZE FILE NAME: [Yourfilname] - Drill Info.rep
SPECIAL INSTRUCTIONS FILE NAME: Unidentified--
MULILAYER STACKUP FILE NAME: Unidentified--
Thanks to Andres Gomez (NI Applications Engineer) for your help.
Kel
(4,736 Views)
Hi Kel,
Thank you very much for the information, I am pretty sure this can be a great source of help for other engineers that can be looking into the same information !
Sil.VI
(4,662 Views)
