Multisim and Ultiboard
Ultiboard Commands Missing
I recently upgraded to Ultiboard Rev 11.0.2, and I've noticed two commands are missing on the drop down menus. Under Edit, In Place Part Edit is missing, and under Transfer, Highlight Selection in Multisim is missing. I've checked this across several designs I've done in the past, as well as new design work started after the implementation of the up rev, and the commands are missing. I've also restarted my machine just to be sure everything loaded.
Is there a bug in the new software revision affecting these two commands? Has anyone else encountered this problem? Please advise.
(4,059 Views)
What's your Ultiboard Edition? These two features are not included in Ultiboard Full Edition. Here is comparsion table.
To verify your version go to Help>>About Ultiboard.
Fernando D.
(4,053 Views)
I am using the Power Pro Edition.
(4,042 Views)
Delete the Ultiboard configuration file, this will restore all the menus and toolbars.
  • In Ultiboard go to Options>>Global Preferences.
  • Select the Paths tab.
  • In the User settings field you will find the path to the configuration file (*.ewcfg).
  • Close Ultiboard, locate and delete the configuration file.
  • Launch Ultiboard, a new configuration file will be created.
Please let us know how this works.
Fernando D.
(4,023 Views)
Success! Thanks!
(4,019 Views)
I am glad to hear that the issue has been resolved.
Have a great day!
Fernando D.
(4,013 Views)
