Multisim and Ultiboard
Ultiboard 'Follow Me' DRC violations
Laying tracks using any of the line tools often results in the gap between the track and the pad to which is connected being below the minimum track-gap value or 'Clearance to Trace' value set in the pad configuration.
In the attached screen grab the min values are set to 0.128mm whereas the gap trace-to-pad is 0.09mm which causes slivers of copper, and trace lifting during manufacture.
(2,155 Views)
Hello spoof,
Could you please send me screenshot of all rules you have set?
__________________________________________
The best way to thank, is to give KUDOS
(1,950 Views)
