Multisim and Ultiboard
Ultiboard PCB Outline
Hi everybody, I'm new to Ultiboard and trying to throw a quick board together.  I'm trying to remove the optical placement targets that appear in the upper left, lower left, and lower right corners of the PCB, since their size is interfering with having the board milled.  Is there any setting or option in Ultiboard that I can use to remove them (since they don't seem to appear anywhere in the actual board design on any of the layers)?  If it helps, I'm exporting to Gerber RS-274X files.  Thank you for your help.
(4,003 Views)
Accepted by topic author bobsmith405
These marks are the fidicials. You can remove them in the Global Preferences.
  1. Click Options > Global Preferences
  2. Select the PCB Design tab
  3. In the lower right corner, uncheck Show fiducial marks
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(4,001 Views)
Thank you very much.
(3,981 Views)
