Multisim and Ultiboard
Ultiboard: how do you build a slot
How do you build a slot in Ultiboard?
That is, I have a component with 0.5mm x 1.5mm leads and I need to drill a rectangular hole.
Can I do this with Ultiboard 2001?
Alan Nishioka
(4,764 Views)
select the board layer, place shape > rectangle.  Set to  your dimensions and  you should be good to go
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
(4,743 Views)
But that won't have any effect on the drill file, will it?
I need a rectangular hole, not just a rectangular pad...
(4,741 Views)
when you say slot, you mean an indent into the board, but not all the way through?  I thought that was referrenced as a score, not a slot.  I've always understood slots are equal to through holes with different shapes.  Scoring is creating a mark into the fiberglass X distance into the fiberglass but not all the way through.........assuming my facts are straight, to which are you referring?
(4,732 Views)
I mean a long hole.  Taking a router bit and moving it sideways one millimeter.
I need a long plated through-hole to solder in a metal tab.  (To mount a TV tuner component, specifically)
(4,730 Views)
I just re-read your reply (Thank you for responding!)
Are you talking about drawing in the "Board Outline" layer?
Can I use this to create a plated through hole?
(4,729 Views)
