Multisim and Ultiboard
Ultiboard maximum trace width. Cant resolve Problem
I have the following problem.
I tried to design a Atenna (just a normal trace) with a thickness of 1.5mm. Since my Design Rules only allow 1.0mm, I changed them to 1.6mm. Ultiboard seems to refuse these settings since it still says:
    Design rule error: The object "Trace: Net(3); Clearance(0.150000 mm); Width(1.500000 mm); Layer(Copper Top)" has a width BIGGER than allowed by the net settings.
 Im using Ultiboard 13
regards
(5,458 Views)
Hi there,
There is another way to change the trace width. In the Spreadsheet View, Select  your Net (3), you can see it's Max, Min and Trace width. You can modify them here.
Hope it helps!
Chen_T
(5,443 Views)
