Multisim and Ultiboard
Ultiboard user footprint doesn't show up in Multisim footprint dialog box
I can't get Multisim's footprint selector dialog box to access certain parts I made recently in Ultiboard. I've been doing this a long time and never had this problem. Design suite version is 10.1 and OS is Win7 Thanks
(3,675 Views)
Hi Todc,
Sometimes you have to restart Multisim to refresh the footprint view in Multisim.
Tien P.
(3,668 Views)
Thank you Tien, I tried shutting both Multisim  and Ultiboard down and restarting them without result. I tried making different parts to see if any of the names i was using might be creating problems. I finally rebooted the PC and the part I was trying to link to the Multisim database, finally linked. I had the same problem with the next part I made and tried rebooting the PC again, but this time it didn't work. Coevally with this problem, I could not see the top[ copper layer in the process of making parts with the wizard (only the silkscreen layer). I deleted the ub_config file and solved that problem, but the MS database link is still a problem. I plan to delete the ms_config file tomorrow to see if that is whats causing the hang up. Apparently something happened in this machine that screwed up the design suite. I'll let you know what happens when I delete the ms_config file if you wish. I welcome any insights you might have. Thanks, T
(3,662 Views)
