Multisim and Ultiboard
Ultiboard v10 Polygon Problems
Ultiboard v10 appears to have very little support for copper polygons.  Yes, I can draw them, but I do not the have the option of assigning a specific net or splitting them.  The software does appear to provide clearance for unrelated traces.
I do know these options are available in Ultiboard v9.
Suggestions?  Updates?
(4,841 Views)
Once you place a copper polygon (area), just select it or double-click on it to get its properties window, on the properties window look for the tab named Copper Area, and on the first window you can have it attach to a specific net that you decide.
To split it, just go to Design >> Polygon Splitter.
Nestor
(4,837 Views)
Wrong version.  Ultiboard v10 has "Polygon" tab in place of the "Copper Area" tab.
The polygon splitter does not work.
These features work in Ultiboard v9.
(4,833 Views)
No, actually I am using v10. Now that you mention the Polygon tab I know what you are talking about. Select your polygon, and then go to Design >> Shape to Area. Then try again what I said before. You should see it now.
When you create a Copper Area, you should use Place >> Copper Area. I believe you used Place >> Shape >> Polygon. Its just a misconception, the first one is used directly to create copper areas, the second one is used to directly create drawings, like Silkscreen for example, or actually, just a copper 'shape' with no net assignment. If you want it to become an 'area' for which you could use a net assignment, then use that function that I mention at the top of this post.
Polygon splitter only will work for Copper Areas, not shapes. So now that you change the shape to an area you should be able to split it.
So, I will summarize two requests for the software from this post:
1. Either integrate polygon shapes and areas into one function or make it more descriptive for users.
2. Polygon splitter should also be available for Shapes and not only for Areas.
Nestor
(4,827 Views)
Thank You
(4,821 Views)
