Multisim and Ultiboard
Ultiboard
How do I remove just a portion of a power plane after it has been placed on a layer. I want to do this so I can create some extra space between it and components, and to remove some small sections of it that stick inbetween components and pads.  I tried the Splitting Copper function, thinking I could just then remove the resulting island, but it won't split small sections for some reason.
(4,111 Views)
Have you tried Edit>Copper Delete>Copper Islands. Don't know if it will work but worth a shot.
Message Edited by lacy on 09-06-2008 09:21 AM
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(4,099 Views)
While on this subject, I have a suggestion for NI about this. It would be nice to have an eraser tool like any other drawing program does that we could run over the board and erase what we don't want there.
Have a Nice Day
(4,095 Views)
HI Lacy,
I've added this suggestion to our feature suggestion tracker.
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
(3,997 Views)
NI's solution was to increase the clearance of pads or vias in the general area of whatever you want to remove.  This works in some cases, but isn't really, in my opinion, a permenant solution.  I like the suggestion to have an eraser tool.  Or at least allow us to draw a polygon and have everything inside it deleted.  I know this works on the soldermask layers. Everywhere you draw a polygon, solder mask is removed.
(3,985 Views)
i agree, the power plane functionality is very limited, an eraser tool would be a very good addition to the software
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
(3,983 Views)
