Multisim and Ultiboard
Ultiroute 9 Power pro question about not being able to remove a net from routing on a layer
I can't remove 1 net (gnd) from routing on layer 1 in spreadsheet view.  I can change all other nets on my design to route on all (1111) or no (0000) layers, but not the gnd net,  it always ends up (1000).  I tried renaming the net and removing all components connected to that net, but still it wont let me delete it from from layer 1 (top).  I'm doing a 4 layer board.  If anyone has any ideas, I'd be gratefull.
(3,556 Views)
This is a follow up to the question I just asked.  By playing around some with my design, I found the same thing happening when I just copied a component (a capacitor) and placed it on the board.  If I use the netlist editor to connect one of the pads of the new component to a net, say net 2, then when I go to the spreadsheet edit area for net 2, I can't get net 2 to not route on layer 1 (want 0000, but can only get 1000).  I don't know if this is related to the problems I was having with the gnd net in the previous posting, but it has the same symptoms.
(3,548 Views)
Can you post the file you are having trouble with?
Nestor
(3,531 Views)
