Multisim and Ultiboard
Ultrasnic Range Sensor
Hello guys i will be doing a project on Labview.
In this project, there will be 4 Ultasonic Range Sensors (Probably SRF02). It will be connected to
NI9403 32-Channel, TTL Digital Input/Output Module
I was wondering what to do when i create the labview file, how to measure a distance on LabView using Ultrasonic sensors.
Also if you have any examples i can take a look at them.
Once i've done the programming on the LabView i can connect cRio Chassis and do the test.
Thanks a lot.
(2,958 Views)
Hello erkan-uk,
It appears you have posted a LabVIEW and cRIO question under the category of 'Circuit Design Suite' where the subscribed readers are more likely to know more about about Multisim and Ultiboard.
I recommend that you post your question under the forum linked below for a chance of a more useful response.  If someone does not post, an NI Application Engineer should pick it later on this week.
OR
George T.
Senior Applications Engineer
National Instruments UK and Ireland
(2,946 Views)
