Multisim and Ultiboard
Unsupported component prefix type '$'
I am designing a circuit that uses the LP2951 adjustable micro power voltage regulator chip. I have gone through the tutorial on how to add a component correctly for simulation. I have downloaded the SPICE file (model) from the TI website and loaded into the component I created. I cannot seem to run the simulation without 152 errors.
List of errors:
------ Checking SPICE netlist for Design1 - Wednesday, March 20, 2013, 12:21:08 PM ------
SPICE Netlist Error in schematic RefDes 'u5', element '$cdnencstart': Unsupported component prefix type '$'
SPICE Netlist Error in schematic RefDes 'u5', element 'lp2951__regulators__1': Due to errors, the component '$cdnencstart' has been omitted from the simulation
SPICE Netlist Error in schematic RefDes 'u5', element 'eee8c5c7a2bc4b01f045f303678664e7916da0bae22e8cb0bba041dd67c69ce448ea70148a9ac1670c8926c1ac5057c8ccfcd77bf87ca9dc3b136f25971a4f2f': Not enough nodes found
SPICE Netlist Error in schematic RefDes '', element 'comp_hys_basic': Due to errors, the component 'acb8ad34256d3a825b65672c4d94c8cb25b87637647200382239fcf2a55d0baaec21c91a5d01fab6badadecdc709d49f963c699df1a4727e1c7f02b1ce3538ca' has been omitted from the simulation
SPICE Netlist Error in schematic RefDes '', element '90f0508f0cfa89b2e1a6d7cef3c8761446eed1c56b41c398ab8e5fd5f3814c73b5f1c17ee795630375617d1c206eb61af812788557dbc82ff046ff810e973c73': Unsupported component prefix type '9'
SPICE Netlist Error in schematic RefDes '', element 'comp_hys_basic': Due to errors, the component '90f0508f0cfa89b2e1a6d7cef3c8761446eed1c56b41c398ab8e5fd5f3814c73b5f1c17ee795630375617d1c206eb61af812788557dbc82ff046ff810e973c73' has been omitted from the simulation
SPICE Netlist Error in schematic RefDes '', element '$cdnencfinish': Unsupported component prefix type '$'
SPICE Netlist Error in schematic RefDes '', element 'comp_hys_basic': Due to errors, the component '$cdnencfinish' has been omitted from the simulation
======= SPICE Netlist check completed, 152 error(s), 0 warning(s) =======
Hoping to find a solution to this problem.
(5,038 Views)
HERE IS THE MODEL FILE FOR THE LP2951....what's wrong with it or incompatible with multisim?
http://www.ti.com/product/lp2951-n#toolssoftware >> on the right side of the page is the SPICE files for the LP2951
HELP...
(5,034 Views)
Did you look at the file with a text editor?  Here are the first 4 lines:
**$ENCRYPTED_LIB
**$INTERFACE
* LP2951 Model
Unless you have the means of decrypting the file, I doubt this model will do you much good.  The only things in plain text are some comments and the .SUBCKT declaration and .ENDS lines.
Lynn
(5,022 Views)
