Multisim and Ultiboard
Using PCM save files as signal generator
Hi everybody,
i´ld like to know if there is any way to use a .wav file (44,1khz 16bit/or anything else) to generate a a testing-signal. i´ve recordet my bass guitar and i wanna use the signal to test my newly designed audio effects. if it is possible to use wave files to generate a signal, is it also possible to output that signal into a pcm wave file, or to send it directly to the pc speakers? thank you very much!
(3,951 Views)
Hello Jean,
yes of course its possible to use labiew steps in Multisim and with this steps you are able to generate waveform or read in a sound signal.
Kind regards,
Elmar
(3,934 Views)
