Multisim and Ultiboard
Using current probe in capacitive circuit
HI
I am required to measure the current flow during charge and discharge of a capacitor with respect to t.
I have initially carried out a transient analysis and selected the I to be displayed however its not very clear and my tutor informed me its recommened to use the current probe, however there are settings associated with it which im not very familiar with.
I have tried to use the current probe i have connected the output to an oscilliscope, seems to be working however i need to know the current flowing once 50% of the Vc is dropped I also need to find time taken for the Vc to fall by 50% so i somehow need to view the current and voltage on a same graph so I can determine once Vc has fallen by 50% the respective circuit current at this time.
I also need to view circuit current after 3CR, so if there is a method of implementing time into the current probe so i can view current at a respective time.
Appreciate any help!
thank you
(5,452 Views)
Hi Hass,
We can add the Measurement Probe to the Capacitor.
Run the simulation, we can find the current information dispalyed  in the box next to the probe1.
To have a better view of time, we can use the Transient analysis. In the Transient analysis output tab,  choose I(C1) as the only output then you will see the current starts from -3mA to 0.
Chen_T
(5,402 Views)
