Multisim and Ultiboard
Using current probes and distortion analyzers
We're doing a research on Li Ion battery simulation in multisim. We've modeled a wireless charging circuit and a battery model. Now we need to test THD in our bridge rectifier, but the problem is that when I connect either a current probe or a voltage controlled voltage source, the measurements goes nuts. The battery current goes up to 200A~ (should not be more than 72A) and then suddenly dips below 1A. When I increase the coupling coefficient in the coupled inductors, the problem goes away, tho the current still goes up more than it should. I would like to find a solution with which I could keep all the component settings as it is, since they're working fine if the current probes are not connected to it. What could cause this problem? Attaching the schematic
Message 1 of 1
(1,935 Views)
