Multisim and Ultiboard
Using the NI6551 Instrument in Multisim
I would like to use the Digital Waveform Generator. I have Student Version 11.0. I followed the below instructions.
  1. Close NI Multisim if open.
  2. Open the attached 5926_waveform_gen.zip file.
  3. Select My Computer.
  4. Browse to C:\Program Files\National Instruments\Circuit Design Suite 10.1\lvinstruments.
  5. Save the NI655XGenerator.llb file from the zip file to this folder.
I don't have the same toolbar listed in this doc..
http://zone.ni.com/devzone/cda/epd/p/id/5926#toc1
Is this because I have the student versions of Multisim and Labview or am I just being obtuse?
Thanks for your help!
(4,274 Views)
Hi montech,
You should be able to use LabVIEW instruments in the student edition of Multisim. The file has to be saved to the following path C:\Program Files\National Instruments\Circuit Design Suite 11.0\lvinstruments.
In version 11.0, the instrument toolbar is on the right side of the window.
Hope this helps.
Tayyab R,
National Instruments.
(4,250 Views)
I did save it like this:
(4,246 Views)
CAP039.jpgAnd It just isnt here! I appreciate any help. I just dont understand whats wrong.
(4,244 Views)
If you click on the LabVIEW symbol on the toolbar in the right, you will see the LabVIEW instruments. Take a look at attached screen shot.
Tayyab R,
(4,240 Views)
As I said the instrument isnt there.
(4,198 Views)
I am also having the same issue. I'm trying to do this tutorial in MultiSim 14.1. I've saved the file to the proper location, and it is not showing up in the Labview instrument menu. I'm not sure where to go from here. I need to generate a pulse to test my circuit.
Mike
(3,383 Views)
