Multisim and Ultiboard
V-scoring -- how to in Ultiboard
has anyone figured out how to use a v-scoring tool in Ultiboard in order to pre-panelize boards?
(3,388 Views)
Hi Jackiinj,
Ultiboard doesn't have an option to panelize a board so V-scoring is also not available.  You should contact the PCB manufacturer that will produce the board, they have a Gerber editor which they will use to panel you board and they should be able to add the scoring for you.
Tien P.
(3,377 Views)
