Multisim and Ultiboard
VCVS Component - Help Needed Finding Vx
Hi there.
My background is in mechanical engineering, but I recently developed an interest in digital electronics. I decided to teach myself Multisim using the book Circuit Analysis with Multisim by Lopez and Guerrero-Castro.
I'm doing the problems chapter by chapter, but have found myself stuck in Ch. 2.Capture.PNG
The question requires a VCVS. So far so good, because I know where to find them in the component browser.
However, I don't know which components to use to get R2 and E1 to be the exact same ones in the figure.
A little help, please?
I've attached the file I've worked on.
Thank you.
(3,116 Views)
The second answer on the following link, since to have the answer for your question:
https://forums.ni.com/t5/Multisim-and-Ultiboard/Dependent-sources-circuit-need-help/td-p/1516768
(3,075 Views)
Thank you for the help.
(3,071 Views)
